Car is hesitating and making popping noises
Old 03-12-2008, 07:28 PM
Alero99
Alero99's Avatar
Default Car is hesitating and making popping noises
when i step on it in any gear the car will have nothing and start to buck and make wierd popping noises... WTF! help please
Alero99 is offline
Old 03-12-2008, 07:34 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Car is hesitating and making popping noises
are you still trying to figure out the prob???..what have you done to find prob/ replace??
mjr46 is offline
Old 03-12-2008, 07:40 PM
z24stang
z24stang's Avatar
Backfiring? Weird my car was doing the same thing last year before I put her away.I was playing with the timing,perhaps thats something? Subscribing.
z24stang is offline
Old 03-12-2008, 07:42 PM
89GreyStang
89GreyStang's Avatar
Sounds like the timing is advanced too far.
89GreyStang is offline
Old 03-12-2008, 07:48 PM
Rajun_Cajun
Rajun_Cajun's Avatar
It sounds like spark knock.
I know when I put a C&L MAF on my car, it threw my tune off and caused me to run lean. When I would take off fom a stop, it would fall on its face and make all kinds of crazy popping noises until I got to about 2000rpm. Anything above 2000 and it drove fine. I ended up taking it off and selling it and went back to my stock MAF. It runs like a champ now.
Rajun_Cajun is offline
Old 03-12-2008, 08:24 PM
94StinkinLincoln
94StinkinLincoln's Avatar
NOT JACKING THE THREAD...
ragin, where is Oberlin? i live in the Bush/Covington area.
dirty maf, lean, rich, timing to retarded or advanced, not enough octane, dirty iat sensor, bad coil, tfi module, or dizzy, cap and rotor. im guessing the dizzy and tfi arent the problems, they norm dont allow car to start or run, at all or just kill at random, esp. when hot.
94StinkinLincoln is offline
Old 03-12-2008, 08:54 PM
Old_Smokey
Old_Smokey's Avatar
Okay so Far i have done a basic Tune Up
Fuel Filter (old one was FILTHY!)
Cap and Rotor (motorcraft)
Wires are FRPP 9mm but they are old and beat up... its getting worse and worse...
and yes after a certain rpm it seems to pull like normal but still does not feel 100%
sorru this is alero99 posting from my cousins account did not realize he was logged in and not me
Old_Smokey is offline
Old 03-12-2008, 09:00 PM
aode08
aode08's Avatar
Is your MAF installed straight up , not sideways AT ALL?
Clean your MAF element(the tiny spring ) with ELECTRICAL CONTACT CLEANER, naything else, its ruined(unless alcohol).
Make sure the spring is in a straight position, not bent or broken. It will be white, not black, when complete.
Also check the ground wire on the driver side head(Orange) for the HEGO(Oxygen Sensor), I see you had some work done, they like to break, or become so corroded, its useless.
aode08 is offline
Old 03-13-2008, 12:13 AM
Alero99
Alero99's Avatar
its SD no MAF
Alero99 is offline
Old 03-13-2008, 12:18 PM
Alero99
Alero99's Avatar
TTT
Alero99 is offline
Quick Reply: Car is hesitating and making popping noises
