tps
Old 03-13-2008, 06:51 PM
JamesIngerman
JamesIngerman's Avatar
Default tps
can i run my car without the tps???
JamesIngerman is offline
Old 03-13-2008, 07:43 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
Default RE: tps
rmodel65 is offline
Old 03-13-2008, 07:49 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: tps
ORIGINAL: JamesIngerman
Yes, let us know how it works out!!
PRO50SC is offline
Old 03-13-2008, 07:58 PM
JamesIngerman
Default RE: tps
well since everyone is going to poke fun at it let me ask you all this when i buy the new one is there any special way i have to put it on ??
Old 03-13-2008, 08:04 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: tps
OK, we have a tech section
https://mustangforums.com/m_2141191/tm.htm
You will find a lot of helpful articles including how to set/replace a tps.
BTW, why do you think you need a new one?
PRO50SC is offline
Old 03-13-2008, 08:27 PM
dudeboy
dudeboy's Avatar
Default RE: tps
I don't really care for the TPS '!!!Tech Article!!! here...
https://mustangforums.com/m_4613249/tm.htm
jason
dudeboy is offline
Old 03-13-2008, 11:07 PM
JamesIngerman
Default RE: tps
because the spring in my no longer "springs" when i hit the gass and let off it doesn't spring back to reading idle
Old 03-14-2008, 03:52 AM
Hung Like a Stang
Hung Like a Stang's Avatar
Default RE: tps
I'm having a hard time understanding what you mean there..
All you need to do is back probe the signal and ground wire (green signal and black ground) with a dvom (voltmeter DC) KOEO (key on engine off) and make sure it reads about .98-1V at idle (throttle closed) and around 4.5V at WOT. Go slow in the middle too to see if it doesn't read. If it does not to that, then you can condemn the TPS.
Hung Like a Stang is offline
Old 03-14-2008, 08:13 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: tps
That's not a tps problem. It's an accelerator cable or return spring problem or maybe something w/ your throttle body is sticking.
PRO50SC is offline
ShaneB26154
35
03-04-2021 04:05 AM
mirandaandjimmy
11-16-2015 08:51 AM
JonnyBlazeGT
11-03-2015 01:10 AM
69MustangCoupe393cid
10-03-2015 10:33 AM
bmorrisj
05-27-2004 06:18 PM
Quick Reply: tps
