rough starting
Old 03-13-2008, 10:29 PM
green95GT
green95GT's Avatar
Default rough starting
ok so lately my car has been starting really rough. it will sometime start on the 3rd or 4th time i crank it over. but most of the time it takes longer than that. i know its not my coil i have a brand new performance one i put on. and it did this before i put it on so thats not the problem. I pretty sure im getting fuel because i can smell it so i think im not getting a good spark or something. And mods are in the sig. and my timing is bumbed to 14 degrees.
anything would help thx
green95GT is offline
Old 03-13-2008, 11:40 PM
Ridinsidewayz
Ridinsidewayz's Avatar
Default RE: rough starting
If you can get it running I would double check your timing that can cause a poor idle and starting problems. If you can smell fuel you might be getting too much fuel. Is the car fuel injected and does it have a mass air sensor? Your coil may be good but your plugs r wires might be messed up. Hopefully it's something simple. I'm sure you'll figure it out. Good luck.
Ridinsidewayz is offline
2007StangV6
01-28-2016 06:09 PM
StalkerGT
09-25-2015 02:41 PM
musnicki
09-23-2015 07:11 AM
zanemoseley
09-06-2015 12:58 PM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: rough starting
