Nitrous
Old 03-13-2008, 11:08 PM
blackstalion
blackstalion's Avatar
Default Nitrous
i have a 93 with about 140000 on it what would the biggest shot of nitrous be that i could put on there.
blackstalion is offline
Old 03-13-2008, 11:23 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Nitrous
^^^until it blows!!!........wet kit will allow you to run the most ..I've seen 200 shots run on stock set ups....but I'd start at 100 and maybe go up to 150.....but above there you really have to watch timing and start changing to a colder plug...cause detonation will kill the motor if your not careful
mjr46 is offline
Old 03-13-2008, 11:30 PM
blackstalion
Default RE: Nitrous
ok thanks so if i deside to do a 75 shot it shouldnt be to much of a problem?
Old 03-13-2008, 11:33 PM
bighungrymatt
bighungrymatt's Avatar
Default RE: Nitrous
yeah 75 will be fine, you will want more though after spraying 75 a few times
bighungrymatt is offline
Old 03-14-2008, 12:20 AM
Rajun_Cajun
Rajun_Cajun's Avatar
Default RE: Nitrous
I would LOVE a 150 shot in mine.
Rajun_Cajun is offline
Old 03-14-2008, 02:58 AM
greenstreak9205
greenstreak9205's Avatar
Default RE: Nitrous
most will tell you to go at least 100 or dont bother. i personally dont have any experience with it though. but as long as your motor is in good mechanical working condition, you will be perfectly fine as long as you set it up correctly
greenstreak9205 is offline
Old 03-14-2008, 10:01 PM
Forged331
Forged331's Avatar
Default RE: Nitrous
I typically see 175 wet max, and 150 dry max (with upgraded fuel pump minimum). I agree with Bighungrymatt too. Nitrous = Heroin....once you take that shot you want more!!
Forged331 is offline
Old 03-14-2008, 10:12 PM
TRexGAWD
TRexGAWD's Avatar
Default RE: Nitrous
Nitrous is a drug chosen by most. It should only be used with respect and never to be abused. A 75 shot would be more than fine. i've seen stock 302's w/ over 150,000 miles handle a 150 wet shot and FI with no problems. Make sure you have supporting fuel modifications and adjust timing as needed.
TRexGAWD is offline
Sandmanbjj
08-21-2015 12:38 PM
mstngdvr17
12-25-2003 04:55 PM
jhogan2424
11-05-2003 08:51 PM
67gt500
08-17-2003 04:01 AM
Quick Reply: Nitrous
