Stang wont Kick over! Neeed help
Old 03-15-2008, 01:07 AM
Black95GTMustang111
Black95GTMustang111's Avatar
Default Stang wont Kick over! Neeed help
hey guys .. Okay get to the point, been driving my car for about 3 year now, always is fine, I went out 2nite and it started up fine. I parked it and about 4 hours later i go back to my car and i put the key in and everytihng goes on .. lights radio, you hear the fuel pump go on . and the car just wont even kick or anyting .. Im pretty positive its not the started . I mean could it be a electrical problem or what?? If anyone knows anytihng plz let me know .. thank you guys
Black95GTMustang111 is offline
Old 03-15-2008, 01:21 AM
FuzzyDiceRule
FuzzyDiceRule's Avatar
Default RE: Stang wont Kick over! Neeed help
solenoid or starter, id replace the entire thing
in the mean time, park on hills and clutch start [8D]
FuzzyDiceRule is offline
Old 03-15-2008, 01:50 AM
green95GT
green95GT's Avatar
Check your battery cables sometime those won't get a good connection.
green95GT is offline
Old 03-15-2008, 09:10 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
ORIGINAL: FuzzyDiceRule
^^^^when all else fails throw every part in the system new on it??....a simple test light is all that is needed to diagnosis the prob..not slap parts til it starts.....first with the key held in the crank position touch the test light to the small wire that goes to selonoid = hot in crank = ignition feed wire for selonoid to be engauged...if hot = ignition switch good.....then with held in crank position still....touch test light to big cable on selonoid that goes down to starter = should light up test light ..if it does and no cranky crank..= bad starter....make sure all connections are free of corrosion and tight
mjr46 is offline
Old 03-15-2008, 11:33 AM
AdderMk2
Banned
AdderMk2's Avatar
I usually do the hammer test before I break out my test light
AdderMk2 is offline
Old 03-15-2008, 12:24 PM
mjr46
mjr46's Avatar
^^^^^yea so do I hmmmmm forgot about that one
mjr46 is offline
Old 03-15-2008, 01:52 PM
getafewlives
getafewlives's Avatar
Hammer test was used as a temp solution on my moms old corolla. No start= bring out the hammer.
getafewlives is offline
Old 03-15-2008, 03:21 PM
mjr46
mjr46's Avatar
ORIGINAL: getafewlives
most of the time on toyotas... you don't need to replace the starter^^^ a set of 6.00 dollar contacts cures a no start/ click only from the starter
mjr46 is offline
Roxon68
03-17-2016 08:13 PM
Bokeo
10-10-2015 08:28 PM
Explosive
10-02-2015 07:45 AM
Florida Regional Chapter
09-30-2015 08:04 PM
stealth_GT
The Racers Bench
09-22-2015 02:19 PM
Quick Reply: Stang wont Kick over! Neeed help
