engine noise after oil change WITH video
Old 03-17-2008, 03:31 PM
  #21
steve r
steve r's Avatar
Default RE: spark plug gap
went back to regular 10w30 and the nouse is still there...its not that loud but Inever heard it before yesterday...ill get a video of it
steve r is offline
Old 03-17-2008, 04:02 PM
  #22
steve r
steve r's Avatar
http://s127.photobucket.com/albums/p...nt=carr066.flv
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i127.photobucket.com/player.s...rr/carr066.flv">
how about any of them?
steve r is offline
Old 03-17-2008, 04:04 PM
  #23
Baddog
Baddog's Avatar
Not workin' there Stevo...
Baddog is offline
Old 03-17-2008, 05:13 PM
  #24
WhiteWindsor
WhiteWindsor's Avatar
The video's work. Check your header bolts and make sure they are tight, i doubt that's the answer but it's worth a shot. If that do's not help your only course of action is to remove the valve covers and see what you have and hope it's not deeper than that. Check your rockers and all valve train components and make sure your getting oil up there. Dont worry about making a mess, just lay a towel down or something.
WhiteWindsor is offline
Old 03-17-2008, 05:30 PM
  #25
mustangsneverdie
mustangsneverdie's Avatar
try to see if you can find what side its coming from then get a long stick or screwdriver pu tit where you think the sound is coming from and put it to your ear
mustangsneverdie is offline
Old 03-17-2008, 05:46 PM
  #26
WhiteWindsor
You saw the video right. This do's not sound like an isolated problem. Could be loose rockers, could be clogged oil pump not pumping oil up there, could be lifters, could be alot of things man. I think your going to have pull the valve covers. I believe you have to pull the upper off to get to them but i'm not sure. Been awhile since i've fooled with an efi stang.
Old 03-17-2008, 06:56 PM
  #27
94StinkinLincoln
94StinkinLincoln's Avatar
sounds like my aftermarket roller rockers...
94StinkinLincoln is offline
Old 03-17-2008, 07:06 PM
  #28
302f150
302f150's Avatar
dumb question...but how's your oil pressure? does it drop when the car warms up?
302f150 is offline
Old 03-17-2008, 07:46 PM
  #29
steve r
steve r's Avatar
my oil pressure shoots right up, and Im not sure whats done to my car ive been told it has work done to the motor and the sound is just the after market rollerrockers but it never made the noise till now
steve r is offline
Old 03-17-2008, 07:52 PM
  #30
aode08
aode08's Avatar
where the plugs you removed the same as you replaced?
where they colder than the ones you replaced them with?
do you have power when you floor it?
aode08 is offline
Quick Reply: engine noise after oil change WITH video
