Vacuum pumping the crankshaft
RE: Vacuum pumping the crankshaft
I have seen the vaccum pumps and systems in jegs and summits, but I have yet to see one installed on a car at the local track here, even on 4 second 1/8 mile cars. I have seen header collectors set up with hoses going from the valve covers to the collectors to create vaccum in the crankcase. I asked and told that on n/a motors with lots of compression and making over 500 hp it is good for about 25 hp
ORIGINAL: FASTBLACK
I've read of people getting that much hp with a good system. But it depends on your set up. You will gain much more hp with a 500 cid engine than what you would say with a 302 small block. It depends on how powerful the engine is in the first place and i've READ it depends on compression of engine also.
ORIGINAL: ericdk5.0
Dry sump lubrication. Mainly for extreme cars that see high g conering/launching, so the oiling system never has any "hiccups." Only necessary on full on race cars,a nd some very high end sports cars. They're quite expensive to setup.
ORIGINAL: Fatboy Racing
i have all the info i need please delete
ORIGINAL: chrajohns0
thats funny!
ORIGINAL: my77stang
are you gonna replace your muffler bearings and change your turn signal fluid too?
thats funny!
ORIGINAL: ericdk5.0
Was installed in a 306 N/A making 9.6 - 9.5 ETs in the 1320' ........ it does help in the power production dept.
http://www.hartracing.com/rich970.mpg
jwog666
12-27-2021 08:09 PM
mrappe
09-26-2015 10:16 AM
