Electrical dillema
Electrical dillema
history of problem: Temp Gauge does not work, Gas guage does
[hr]
[hr]
Replaced sensor at engine
tried to ground out end no movement
hookedup a toner tool and get continuity until i plug in to back of cluster then nothing
replaced temp part of cluster
i am out of ideas anybody have a clue what else i could try, i dont want an aftermarket gauge. this has been buggin me for over a year and i am at wits end...
1995 mustange 5.0
improvements in the last year
cold air intake
exhaust
new top (Convertable)
new radio
new antenna
new gear
new wires/plugs
sub frame connectors
[hr]
[hr]
1995 mustange 5.0
cold air intake
exhaust
new radio
new antenna
new gear
new wires/plugs
RE: Electrical dillema
ok, i foung part of the problem, the actuall end that plugs into the sensor was bad, i cut that off and spliced in a wire and grounded it at that jumps the gauge to hot, which it never did before but when i hook it up to the sensor nothing, i recently replace the temp sensor (second time) i still have the old one. when i installed it i used teflon tape, could this causing the gauge not to work? I am ready to pop.... somebody must had cured this problem HHEELLPP!!!!!!!!!!!!!!!!!!!!!!!1
mrappe
09-26-2015 10:16 AM
uberstang1
09-20-2015 06:42 PM
TfcCDR
09-14-2015 12:08 PM
