im throwing my edelbrock performer heads on this weekend...i jus bought all new arp hardware for the heads intake and headers...what should i torque the cylinder heads down to? i was gonna so stock but these heads are aluminum thanks
first pass all to 33 ft lbs.....second to 55 lbs all and follow sequence each time and final pass 80 ft lbs on the long bolts and 70 ft lbs on the short ones
Installation is the same as for original equipment cylinder heads. Consult service manual for specific procedures, if necessary. Head gasket recommendations are listed in the head gasket section. Be sure that the surface of the block and the surface of the head are thoroughly cleaned to remove any oily film before installation. Use alcohol or lacquer thinner on a lint-free rag to clean. Apply moly-oil mixture to head bolt threads, washer, and area under head bolt to prevent galling and improper torque readings. Torque to 70 ft./lbs. for 7/16" bolts in three or four steps following the factory tightening sequence, then tighten the long (upper) head bolts to 80 ft./lbs. A re-torque is recommended after initial start-up and cool-down (allow 2-3 hours for adequate cooling).
Thisis directlyfrom he Edelbrock installation instructions, as you can see mjr46 is spot on as usual. primetime5.0 if you did torque all your bolts to 80 you may be increasing the potential for warpage if your engine gets hot.
