How many wires are on the starter solenoid
Old 03-20-2008, 01:09 PM
crusin92red5.0
crusin92red5.0's Avatar
Default How many wires are on the starter solenoid
CAn anyone help me out. i need to know how many wires are connected to the starter solenoid. Right now i have tons of wires on the left post. and a couple of wires on the right. I recently re-wired my alt with a bigger wire and now i cant screw the nut on the solenoid. does anyone have any pics? how many wireson each side? which wires should be on which side? Do they sell solenoids with longer bolts? thanks
crusin92red5.0 is offline
Old 03-20-2008, 01:46 PM
Joel5.0
Joel5.0's Avatar
Default RE: How many wires are on the starter solenoid
Top RH corner.......
Joel5.0 is offline
Old 03-20-2008, 02:25 PM
crusin92red5.0
still not clear, but thanks i'll check when i get home. can someone explain how the solenoid works so i can get a better understanding. thanks
Old 03-20-2008, 10:14 PM
crusin92red5.0
does anyone know the answer?
Old 03-20-2008, 10:30 PM
ALMOST STOCK
ALMOST STOCK's Avatar
Courtesy of Jrichker
92-93
I have read(no actual experience) that the Ford Motorcraft Solenoid Switch SW1951-C
or Ford Part # Motorcraft SW-1951-C E9TZ-11450-B have a longer stud.
http://www.ryderfleetproducts.com/cg...uct_detail.jsp
http://www.ryderfleetproducts.com/cgi-bin/ryderfp/products/srm/oid/55290/erm/product_detail.jsp
http://www.rockauto.com/catalog/cata...RAFT%2BSW1951C
or
http://www.rockauto.com/catalog/catalog.php?catalog=48&partnum=SW1951C&a=S earch%2Bfor%2BMOTORCRAFT%2BSW1951C
ALMOST STOCK is offline
Old 03-20-2008, 10:40 PM
crusin92red5.0
alright. cool. i know i have way too many wires connected to the solenoid. now i just have to figure out whta wire does what.
Old 03-20-2008, 11:16 PM
ALMOST STOCK
NP[&:]
Old 03-21-2008, 01:53 AM
ptown87
ptown87's Avatar
This probaly won't help but I just did the 130 amp alt swap last week and my starter solenoid was pretty packed. I had just enough room to connect my 4 gauge wire for the alt. good luck
ptown87 is offline
Old 03-21-2008, 01:55 AM
ptown87
ptown87's Avatar
also be sure to upgrade your grounds(from battery to block and from engine to firewall). This is necessary get the best results fromyour alt swapand to reduce resistence and the risk of melting wires down.
ptown87 is offline
jwog666
12-27-2021 08:09 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Dathan
10-05-2015 05:52 AM
logan409
09-26-2015 07:43 PM
Quick Reply: How many wires are on the starter solenoid
