Accessary light not coming on
When you first Turn onyour car, the acc. lights to the left of the steering wheel with the CEL and the other warning lights turns on then turns off right? mine do not come on at all...
Could it be a Blow Bulb or somthing is not connected the right way, as it stands my car is electrically a nightmare, i can't figure out why my reverse lights and turning signals don't work, but my Hazards work perfectly, and my Rear Defroster stopped working
and somhow the rear defroster and the signals and reverse lights are all connected cuz if 1 of them worked they all worked and if none worked... well then none of them worked lol
throw some Ideas at me please
RE: Accessary light not coming on
For your inside light check for a fuse blown or maybe you dont have a bulb connected...
For your signals make sure your blinker fuse is good...also make sure the front signal bulbs are connected the right way...check the same way on the reverse bulbs...
first check the fuse for the defrost and then check the wires from the switch or where they connect in the window...
Have they been working before or they just stopped working...
Just throwing some ideas that i would do first...
Good luck...keep us updated...
hmmm i know my ignition is broken... i can turn the car into any mode with the key... so would that be why i have no warning lights?
also any thoughts on my Signals/ReverseLights/DeFroster...
they worked only toghether... and 1 day decided to crap on me
Diode Dynamics
28
05-26-2022 12:02 PM
