K-member swap ?
Old 03-29-2008, 06:00 PM
  #21
5.0stanger
5.0stanger's Avatar
Default RE: K-member swap ?
My strut bolts sucked too. I heated the nut a little and used a breaker bar with a cheater barand got them loose. The heat makes thenut expand and loosen up a little.
Looks good so far...keep the updates comming.
5.0stanger is offline
Old 03-29-2008, 06:45 PM
  #22
crusin92red5.0
crusin92red5.0's Avatar
my ingersoll 2135 ti impact can take any bolt off. i highly suggest everyone to get one. 219 bucks well spent.
crusin92red5.0 is offline
Old 03-29-2008, 07:12 PM
  #23
r.barn
r.barn's Avatar
She's out. Really get an appreciation for how much weight it drops when you drag the stocker out
and compare them.
Reinstall looks simple. The driver side bolt holes line everything up square and then
the other holes are little oblong to fit whereever the driverside lines them up.
I did a lot of research on k-members. here's what I found.
1. AJE - can reuse stock a-arms and springs. has universal motor mounts for engine swaps (SBC, Mod, LS1)
2. MM - requires full coilover conversion --- best of the best
3. TeamZ - VERY good and best price - requires coilover conversion but will reuse stock a-arms
3. QA1 - can reuse stock a-arms and springs but is pain to install
4. DnD - junk
AJE seems to be as strong as most of the others and have excellent customer service.
TeamZ is cheapest and highly regarded also with strong customer service
MM is the shiznit but you pay for it too.
r.barn is offline
Old 03-29-2008, 08:49 PM
  #24
wildsurfer92
wildsurfer92's Avatar
awesome...so what about say granatelli, they seem to have everything and decent prices, but ive been getting the vibe from people to stay away.? I personally was looking at QA1, but why is it a pain to install?
wildsurfer92 is offline
Old 03-29-2008, 09:09 PM
  #25
r.barn
r.barn's Avatar
QA1 says you can reuse stock A-arms, but supposedly it takes a lot of grinding to make em work.
DnD is really only one I heard just not to get.
If I was going to do a full coilover conversion with the swap
I would either get the MM or TeamZ
r.barn is offline
Old 03-29-2008, 09:35 PM
  #26
wildsurfer92
with QA1 if you go with their a arms, do you have to switch to coil overs or can you stick with regular struts and springs
Old 03-29-2008, 10:02 PM
  #27
r.barn
r.barn's Avatar
It's in.
Sure was fun getting it up and bolted in by myself[&:]
Instruction say to just get all the bolts in and then tighten them
There is about 1/8th inch of slop on where the k-member can go with them loose
Does it not matter? Will alingment take care of any slight off center adjustment ?
r.barn is offline
Old 04-01-2008, 12:37 PM
  #28
wildsurfer92
awesome congrats on the installl.....does anyone here run the granatelli k member, or their suspension components? or know anyone who does? how is their stuff
Old 04-01-2008, 01:20 PM
  #29
PRO50SC
The Rogue Mod
PRO50SC's Avatar
AJE was the most expensive piece I found when shopping. I wouldn't put the D&D rig down to badly. Mjr46 has that one on his car and he likes it. It seemed pretty nice to me when I looked at his.
PRO50SC is offline
Old 04-01-2008, 01:23 PM
  #30
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: wildsurfer92
Ryan, there stuff is not very good from what I've read. I did a lot of research and some one was kind enough to post up some threads about it. If I can find them, I'll let you know. I was considering buying theirs. You can get everything for 5 or 6 hundred bux. But I decides against it after reading up on them.
PRO50SC is offline
Quick Reply: K-member swap ?
