My autometer gauges
Old 03-22-2008, 07:21 PM
BackInBlack90LX
BackInBlack90LX's Avatar
Default My autometer gauges
wheres the best spot to get my power for my wideband a/f gauge and my power for my boost gauge i did some searches but id rather just get a straight answer
BackInBlack90LX is offline
Old 03-22-2008, 07:45 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: My autometer gauges
Boost does not require power. If you mean for the light, tap into your dash or hvac unit. The a/f, you can tap your fuse block.
PRO50SC is offline
Old 03-22-2008, 08:09 PM
TI302
TI302's Avatar
to run multiple accessories just run a relay
TI302 is offline
Old 03-22-2008, 08:34 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: TI302
It's not necessary for gauges. They barely draw any current.
PRO50SC is offline
Old 03-22-2008, 09:25 PM
TRexGAWD
TRexGAWD's Avatar
ORIGINAL: PRO50SC
+1 Tap into the dash or if you can make it look clean find the wire for the light switch and tap that for the boost gauge.
TRexGAWD is offline
Old 03-23-2008, 12:14 AM
nacanitihs
nacanitihs's Avatar
tap into the dash light dimmer switch
nacanitihs is offline
Old 03-23-2008, 01:05 PM
BackInBlack90LX
can i tap into my radio dimmer wire i mean its right there right?
Old 03-23-2008, 03:47 PM
TRexGAWD
TRexGAWD's Avatar
You can tap into anything that runs off the 12v auxilary power. Radio dimmer will work just make sure it's not a constant hot wire or it will always be on. What switch activates your radio dimmer? Because that's the switch that will also turn the light on for the gauge.
TRexGAWD is offline
Old 03-23-2008, 04:17 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
FOR THE LIGHT ALL YOU HAVE TO DO IS FIND THE FUSE IN THE FUSE BOX THAT has current when the lights are switched on.. that's all I did and tapped all the other gauge lights off that wire where I added a tap a fuse in the box...works well...light doesn't draw much current boost gauge.. you just tap off a vaccum port I believe
mjr46 is offline
jwog666
12-27-2021 08:09 PM
andrew1969
16
01-08-2016 02:48 PM
SteelerNation82
09-16-2015 07:11 AM
Pyrate Dave
09-10-2015 07:30 PM
96stang3.8
09-10-2015 06:42 AM
Quick Reply: My autometer gauges
