I am lost with this here.....
Old 03-22-2008, 09:49 PM
ramoyer1
ramoyer1's Avatar
Default I am lost with this here.....
OK i just done a 2.3 to v8 swap and i tried to turn over the motor and i get nothing i took thet starter otu and had it tested it came back great i tired to hook it stright to the battery and othe only thing it does it spark on the post of the battery. What could it be?? maybe i have too small of a starter wire but i dont think so. HELP
ramoyer1 is offline
Old 03-22-2008, 10:28 PM
rust_stang
I ♥ Acer
rust_stang's Avatar
Default RE: I am lost with this here.....
I dont know but your sig is HILARIOUS!!
rust_stang is offline
Old 03-22-2008, 10:57 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you need to check all grounds and b+ cables you should have 12 volts constant on one side of selonoid and 12 volts on the side that goes down to the starter in the crank posistion...and there is a small wire that comes from the ignition switch to the starter selonoid that should be hot in the crank position..if the car you converted was a auto before conversion you'll of needed to of looped the wires on the PRNDL switch to have current from ign switch out to selonoid..just a thought if that's the case
mjr46 is offline
Old 03-22-2008, 11:11 PM
ramoyer1
ramoyer1's Avatar
my was a 5 speed. i left all the wires hooke to the selonoid and the lil wire that pushs omn the post above the 12v side and the starter side. I still cant it to turn over.I am goign to try hooking a jumper cable wire to the starter and then hookign that to battrey to see if it my wire i have ran that might be too small. I only have 2 ground. 1 small wire from battrey to body and 1 fat wire from battery to motor
ramoyer1 is offline
Old 03-22-2008, 11:12 PM
GaryBisiniere
GaryBisiniere's Avatar
get one from cylinder head to the body
GaryBisiniere is offline
Old 03-22-2008, 11:14 PM
ramoyer1
ramoyer1's Avatar
like on the back side of block?? **** that si right there isone back there i seen it and didnt even click untill now... I will hooke that but but still i doesnt think that will fix my problem
ramoyer1 is offline
Old 03-22-2008, 11:17 PM
GaryBisiniere
it should or you gotta check the wires on the solenoid, make sure there on the right side, and is your efi harness the right year? all could be possible problems
Old 03-22-2008, 11:19 PM
ramoyer1
ramoyer1's Avatar
my is carb. i left the light harness and that still works just cant get power to the starter....is there anyway to bypass the selonoid???
ramoyer1 is offline
Old 03-22-2008, 11:20 PM
GaryBisiniere
no
Old 03-22-2008, 11:27 PM
mjr46
mjr46's Avatar
you need a selonoid because it is like a momentary switch... that bridges current from the always hot side to the starter side... you could jump /using jumper cables from the battery to the starter wire and this should allow starter to crank
mjr46 is offline
Quick Reply: I am lost with this here.....
