BAD BAD gas mileage HELP
RE: BAD BAD gas mileage HELP
lol, not likely. you said there is a broken vacuum line.....did you fix that? a major vacuum leak will cause problems. the thing you are talking about sounds like the purge solenoid for you rEVAP system. This normally collects fumes from the gas tank, and then sucks them up into the engine periofically. Make sure there is ABSOLUTELY NO liquid gas in that canister, if there is, then something is messed up and you are leaking gas from places gas shouldn't be leaking. I'm getting 21mpg with a 5speed, no EGR, no EVAP.
did the sea foam first tank full all vaccume leaks fixed maf sensor was bad so was 02 sensor on bank 1 (passenger side )i have 2 friends that are mechanics for local ford dealer they were finaly able to hook up car to computer yesterday i got every thing fixed they also told me i should pull egr & block it off & pull smog pump .ill post more on how mileage turns out next week hopefully my next tank will last that long LOL
ORIGINAL: FASTBLACK
You need to fill up your car and set your trip odom. Next time you fill up see how many gallons it holds and divide that into your mileage.
You can even figure this out without a gas gauge.
To carry it a step further you can first confirm your odometer is reading accurately. Compare it to mile markers OR drive with a GPS reading distance.
5L mileage in the city should be in the teens. Straight highway will be about 20.
I was getting 21 22 highway on mine and like 12-14 city. It wasn't too bad. But I would just check those vacuum line and clean the mass air and throttle bodies see if the air filter is clean also i know its weird but we get this at my job check the tire pressure lol i know its weird but just check it anyway if it ain't set right you wont get good gas mileage and it will help allot some times. You could have a clogged cat on the car as well. Sea foam works pretty good try running that through the car i prefer the carbon clean machines at my shop i work at but most likely you wont have one in your garage. lol
i think i found the final piece of the puzzle a vac hose goes from intace to a cprv valve in to a canister under air cleaner then to fuel tank there are two large nipples on top of canister that draw a vaccume on them i read some where yhey shouls have caps on them . now my question is are the caps vent caps or plugcaps do i need two plug these nipples or plug them ???
thanks fast eddie
thanks fast eddie
Matt's 95 Stang
10-05-2015 07:16 AM
