bad IAC??
bad IAC??
been having some trouble with the stang lately... she has gotten really cranky, mostly at idle. usually when she is idling she is fine but the other 50% of the time she'll search for an idle and occasionally stall out, with the CEL coming on... I'm thinking the IAC may be going on me....
mostly I come across this problem when the lights are on at night. which also has me thinking the car has a charging problem.... which is possible with the whimpy 75 amp alt and the UD pullies that the previous owner put on the car... so hello 3g swap.
anyone know how much a 3g swap alt costs and how much an IAC costs? on a college budget/ saving for an SLP to replace my sidepipes so I dont go deaf
RE: bad IAC??
yeah.....why do people think underdrive pulleys are the cause of all their problems? i have them, and battery relocation. with headlights on, 2 electric fans, and radio i charge fine. IAC is normally bad when the car stalls at a light after driving for a while. it's completely possible your alternator isnt charging, but think about it, has the car ALWAYS acted this way? the alternator may be going out, but if the CEL is on, check the codes
RE: bad IAC??
ORIGINAL: 302f150
RE: bad IAC??
The iac you can take apart and clean yourself, it works alot of the time. As far as your alt., are you running anything extreme that would pull alot of amps? If not the 75 should be fine as long as it's charging around 13.5-14.
RE: bad IAC??
You don't need to go to Advance Auto to get it "scanned"...... save that money and run the DIY KOEO/KOER/Cylinder Balance Self-Test ....save the money in case the IAC does require to be replaced (which I doubt). LUK
RE: bad IAC??
pretty sure the alternator would not trigger the engine light. it would trigger the battery/amp light. the iac could trigger the engine light definitely. run a voltage check for the charging system though.
RE: bad IAC??
ORIGINAL: FASTBLACK
KingRando
10-02-2015 08:06 AM
