Strange fuel pump problem
RE: Strange fuel pump problem
ORIGINAL: mjr46
holley mech pump would be a good way to go...pending on the model you get.. you may need an adjustable regulator
Replace the pump, good luck with lines, I hate busted knuckles
Get some CRC Freeze Off, spray it for 15 seconds on each line, it will freeze and crack the rust and give you power to just turn the line(if you have metal lines).
ORIGINAL: aode08
And Alero99...huh? I'm parking on level ground in my garage, but i don't see how an incline or decline could cause a leak anyway.
