Cracked Intake Flange help
Hey i bought a gt40 uppper and lower intake and when i was tightening the bolts and the front mount cracked and i think its creating a bad vacuum leak, is it repairable? and would this cause the car not to idle properley? also is it repairable or do i have to get a new one
RE: Cracked Intake Flange help
well either the surface is warped...so have it checked or you didn't follow the proper torque sequence...but irregardless I'd find someone who has a tig welder...any welding shop should be able to fix it for you.....when I worked at the college I went to the welding shop /fabricator welded new surface area to my then stock corroded intake ports then I filed them down......it worked and sealed great
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
