o2 sensor harness. someone help please
ok i got the o2 sensor harness i won off of ebay today and trying to get it installed. im not very happy with it since there is a couple wires burned and a pigtail melted. at least its better than my old one. gonna rewire it and also use one of my old pigtails.
anyway the question i have is what is the extra wire for? on the long side of the harness there is a wire that doesnt appear to go anywhere. on my new one it was just there and on my old one it was just hanging around. i cant go off of my old one very much because someone used speaker wire to extend it when they put long tube headers in it.
can anyone help? my cars on stands at the moment and i want to make sure this is right. im also fighting against the rain. its comeing and going right now so im working in between them. i just hope someone knows what im talking about
RE: o2 sensor harness. someone help please
thanks
ok so its not needed? for now i just put it in a wire loom. done a code check and my o2s seem to be corrected. now if i could just get the tps to work right.
ORIGINAL: grabbem88
LOL!.it's funny everybody is having the same problems/sollutions at the same time...i'm still waiting for my o2 harness from ebay..
hope your harness is in better shape that mine was i got from ebay. it was in bad shape. one of the pigtails was melted onto a pigtail for the o2 and wouldnt come loose. so it really only had one useable o2 connector. plus some wires were burned and cracked.
my old harness only had one o2 connector. the other was cut off and had speaker wire spiced into the o2 wires and harness wires.
i ended up cuttin the one good o2 off of my old harness, the one good o2 connector off the "new", and cut about half of the wire off and redone it myself. only took me half roll electrical tape, about 3 feet of wire, some wire loom, 2 burns to my hand from the soldering iron, and about 2 dozen cuss words to get it done. but it works now and thats all that matters.
ORIGINAL: xjarhead1999
thanks
thanks
as far as the O2 sensors go, last time I saw a wiring diagram, some have 4 connections but use only 3 of them, one is a ground, one is current in and the other current out. and they can be killed easily by the fumes from some types of gasket sealer or RTV, so if you use any of this on the engine make sure to check the label and see if it says they are "O2 friendly" sealers.
by the way, do jarheads cuss like sailors or what??? LOL
ORIGINAL: roundman
you might need to use a dremel tool to elongate the adjustment slots in the TPS in order to get it to rotate far enough to get the voltage reading to .98 volts. I had to do this on my'88 model. when you have the voltmeter hooked up, also make sure that the voltage increases as you open the throttle and at WOT it should read above 4 volts. if the voltage don't change, then the resistor in the sensor is bad and you'll need a new one.
thanks
thanks
got a question though about the o2 sensors. when i changed the harness and started driving i guess the car figured out they were there and working so it adapted back to the way it should. i had to play with the idle a little bit to get it going right once i got back home. the only thing wrong now though is it has started backfireing between 1500-2500 rpm. it only does this during the first 30 minutes or so of it running. once the car has been running it wont do it. any ideas about that? it may not be really backfireing because its not as loud as i would expect, but it sounds like a popping sound.
oh and some jarheads do cuss like squids(i mean sailors) but i generally dont. although working on this thing does at times.
damn dude i know what you are talking about!...mine has a little poppty.pop.pop in between gears...do me a favor unplug
it from under your mass air,and drive it .......tell me what it does???
ORIGINAL: grabbem88
