Which oil to use???
Which oil to use???
Hello, as some of you know, I am going to be assembling my engine this week, and I was wondering what type of oil should I use to break it in with. I have heard Rotella 15w-40 Diesel oil is the best thing to use, but I have also heard that the Rotella oil has had the "makeover" and has lost the additive that makes it desireable to use. Is it true that you want more ZDDP? I was looking at Vavoline racing 30W oil, and it has an API rating of SL, and clearly states on the back that it has more ZDDP additive in it. Should I go with this or Rotella? Also, is there any special additives that I can or should put in the oil to help with the cam break in?
RE: Which oil to use???
Ok, well I think they make the "racing" vavoline in 10w-30 as well, and it should have the ZDDP in it as well. But, is that what I need? I already had one flat tappet fail, we already discussed that, and I just don't want it to happen again, b/c now I have a grands worth of rotating assembly that I dont want to ruin. Do you know which API certification he recommends?
Thanks for that link, I just did some checking around and ZDDP is what you need more of. I found a product that is call ZddPlus, which is supposed to be the best ZDDP additive you can buy (according to them). The explain and show a chart that claims to have 4 times as much ZDDP as GM's EOS engine assembly lube. Do you all think I should get some of this??? Its $10 a bottle + shipping.
