steeda oil separator
Old 03-31-2008, 03:11 PM
jperz89lx
jperz89lx's Avatar
Default steeda oil separator
hey, does anyone use the steeda oil separator? (http://www.steeda.com/products/steeda_oil_separator.php) Does it work well? Did you notice any difference in blow-by, or oil consumption?
Any help would be great..thanks
jperz89lx is offline
Old 03-31-2008, 03:44 PM
aode08
aode08's Avatar
Default RE: steeda oil separator
Its cheaper to either add a breather element material($3.00) in the hole, or have a machinist, tap a PCV Intake Hose Adapter Closer to the front of the Intake Manifold and plug the old one.$25
aode08 is offline
Old 03-31-2008, 04:01 PM
golden_eye
golden_eye's Avatar
I considered it but from what I've heard, blow by really doesn't get bad enough to warrant one of those unless you are supercharged.
On the other hand though, I'm sure over time blow by can be pretty bad. I remember when I took the intake manifold off my truck a while back and at 260,000 miles, that thing was coated on the inside [:'(].
golden_eye is offline
Old 03-31-2008, 04:04 PM
jperz89lx
jperz89lx's Avatar
ORIGINAL: aode08
may be a dumb question but what is this material you're talkin about?...lol[&:]
Old 04-01-2008, 02:38 AM
dudeboy
dudeboy's Avatar
ORIGINAL: jperz89lx
It does not change the degree of blowby, but it does help get the oil out of the crankcase gasses before it reaches the upper intake manifold.
I have a similar unit from Home Depot in my 2.3 and 408w Mustangs. They are effective.
Look in the Tools department, with the Air Compressor accessories.
I assume you are asking because you have oil in your intake?
Do you have a baffle installed on the underside of your lower intake? How about in the valve cover, under the filler neck?
Here is some more info that I put together...
http://www.freewebs.com/vristang/pcv...trolissues.htm
(you shouldn't need the second pcv location, but the rest of the background stuff may help...)
good luck,
jason
dudeboy is offline
Old 04-01-2008, 03:40 PM
jperz89lx
jperz89lx's Avatar
cool, thanks for all the info jason...and yes i have oil in the intake[:@]...im pretty sure there is a baffle on the underside of the intake, iv never had the valve covers off so im not 100% sure about the valve covers but yeah...thanks agian
Old 04-01-2008, 07:21 PM
dudeboy
dudeboy's Avatar
ORIGINAL: jperz89lx
When you remove the oil fill cap, you will be able to see...
1. the rockers
2. a baffle
You don't really need to pull the VC's
dudeboy is offline
Old 04-01-2008, 07:33 PM
jperz89lx
jperz89lx's Avatar
ORIGINAL: dudeboy
ORIGINAL: jperz89lx
1. the rockers
2. a baffle
yup, iv' got baffles...i think im gonna try to put a second PCV valve along with an oil separator, see what i get
Old 04-02-2008, 12:09 AM
dudeboy
dudeboy's Avatar
ORIGINAL: jperz89lx
ORIGINAL: dudeboy
ORIGINAL: jperz89lx
1. the rockers
2. a baffle
Have you checked your compression and leakdown numbers?
The second pcv will do nothing if you have excessive blowby (which will show on a compression check)...
jason
dudeboy is offline
Old 04-02-2008, 01:02 AM
jperz89lx
jperz89lx's Avatar
yeah if i woulda read the info you gave mealittle closerthe first time i woulda caught that part...haha[&:]...oh well iv got some diagnostics to do this weekend...(including a comperssion, and vaccumtest)...lol well thanks for all your help man
Quick Reply: steeda oil separator
