KOER code help
Old 03-31-2008, 03:44 PM
telsonman
telsonman's Avatar
Default KOER code help
Ok, so I'm still getting that code 66(my maf was .5v), but here are my KOER codes and if you could help it would be awesome.
55-check ECM pin 5, little or no power. What pin does this go to?
33-EGR did not open/respond during test. I'm guessing this relates to my KOEO codes 85 and 34
94-something about the air system
44-air system inoperable? relates back to code 94?
65- no clue
telsonman is offline
Old 03-31-2008, 04:27 PM
rebelcowboy
rebelcowboy's Avatar
Default RE: KOER code help
hey man i had the code 33 on mine and i changed the egr vacumm soleniod,and the 85 code was the soleniod on the vapor canister,i changed both of them and my codes went away.
rebelcowboy is offline
Old 03-31-2008, 04:28 PM
rebelcowboy
as far as the 94 and 44 i cant help on that one cuz im getting those 2 codes on my koer but i get 11 on the koeo test.
Old 03-31-2008, 04:51 PM
Joel5.0
Joel5.0's Avatar
ORIGINAL: telsonman
65- no clue
The fact that you can run a KOER self test = code 66 is not a "hard failure", a KOER could not be run if a failure code 66 is "current". If by accident you started the engine with the MAF disconnected, the code will be logged as a "memory" code, and it'll show in a KOEO. Suggest to clear codes (disconnect battery for 15-min.) .... and rerun the self tests.
Joel5.0 is offline
Old 03-31-2008, 09:55 PM
telsonman
telsonman's Avatar
so should i go ahead and change the EVP and the vacuum solenoid???
what about those air system ones???
Old 03-31-2008, 09:58 PM
Joel5.0
Joel5.0's Avatar
Clear codes and rerun the tests..... that way you will confirm the real failure codes that need attention......LUK
Joel5.0 is offline
BOB ROME
07-26-2023 01:54 PM
mrtrodonet
09-19-2020 03:12 PM
lincolnshibuya
12-08-2015 04:37 PM
Dathan
10-05-2015 05:52 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: KOER code help
