94 GT
Old 03-31-2008, 08:12 PM
94GTPRO5.0
94GTPRO5.0's Avatar
Default 94 GT
I have a (BONE STOCK) 5-Speed1994 Ford Mustang GT. I was woundering if i were to add a Upper/Lower Intake,Cold Air Induction,E or F Ford Cam,Shorty Headers, 2 1/2" X Pipe, Flowmasters,373 Gears,and a good set of Heads,would i need a Aftermarket Tuner or a Programer?
Plus what size cam should i go with a stock bottom end,and what kind of heads should i go with?
Thanks
94GTPRO5.0
94GTPRO5.0 is offline
Old 03-31-2008, 08:20 PM
94Yellow50
94Yellow50's Avatar
Default RE: 94 GT
i recommend not bothering with the ford letter cams...our cars are picky when it comes to them...either go custom...or for a ots the steeda 19 is specifically designed for the 94-95 5.0s...as for heads..thats kinda unlimited..to some extent..and theres lots of people that run without tunes.but to really get the most outta ur combination u would benefit from a tune.
94Yellow50 is offline
Old 03-31-2008, 08:22 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: 94 GT
cams for the 94...niether...get a steeda 19= designed for your car.....as for a tune after combo is done ..it's always optimal to get a tune to max power output and tune out some small issues with the sn-95 ecms
mjr46 is offline
Old 03-31-2008, 08:25 PM
94GTPRO5.0
94GTPRO5.0's Avatar
Default RE: 94 GT
where can i pick up a steeda 19 cam, and what is the spec on that cam?
Old 03-31-2008, 08:32 PM
94Yellow50
94Yellow50's Avatar
Default RE: 94 GT
only place ive ever seen them is steeda website...and they have some of the main specs on there site about it.
Old 03-31-2008, 08:36 PM
94GTPRO5.0
94GTPRO5.0's Avatar
Default RE: 94 GT
Thanks very much,dont reallyknowto much about 94-95 stangs all i have ever had has been fox bodys a 88 90 92 and 2 93s. the 92 ran mid 8 in 1/4 it had a 331 stroker.
Old 03-31-2008, 10:47 PM
OnyxCobra
OnyxCobra's Avatar
Default RE: 94 GT
Steeda #19
.480 lift w/ 1.6 rockers
220/226 Duration @ 050
RPM Range: 2300-6000
115° LSA
OnyxCobra is offline
Old 04-01-2008, 08:43 PM
94StinkinLincoln
94StinkinLincoln's Avatar
Default RE: 94 GT
you need a tune when u put heads and a cam in.
since u are getting a tune, get a bigger cam lol
i have a xe270hr-114 (218, 224 duration .512 lift 1800-5800, pulls to 6, any more idk i havent gone that far yet), i would go with a xe274hr or slightly bigger
94StinkinLincoln is offline
