Spark plug threads worn...easy fix???
The threads onmy block where a spark plug goes are worn out slightly, and the plug can be wiggled lose. Does anyone know of a easy fix for this...or am I in for a treat?
Thanks for the help.
RE: Spark plug threads worn...easy fix???
Easy depends where it is on the engine. If its in the back it is more difficult but autopart shops sell a helicoil set for such a problem. Neverdone a sparkplug with a helicoil myself but have used on intakes and exhaust manifolds.
It involves drilling out the remaining threads and tapping a larger thread for a helicoil insert to thread in, once in you break the retainer and it is there for good or so they say, then your spark plug threads into it.
I assume your threads are in pretty bad shape but you also be able to tap the existing threads to get few miles down the road.
Heres a link I found real quick for helicoil sets but like I said they have them at most autoparts places.
http://www.shop.com/Auto_Tools+%26+G...1-k36-st.shtml
EDIT: Talked to a buddy and he mentioned just replacing the head, so there you go
Hope it works out for you, let us know. You probably should bring that cylinder to TDC to make sure and filings can be vacuumed or removed easily unless their kitincludes a way to capturethem better.
ORIGINAL: brentloftis
Metal will F up a motor real fast.
Don't helicoil with the head on the motor [:'(]
In order to properly drill the plug hole, you want to pull the head.
Metal shavings don't belong in the CC... [&o]
jason
Doesnt offend me, I have never used the kit only seen it sold. I do think everyone knows metal in the chamber is not good. I am sure the kit has a system setup to either prevent it or instructions to remove the head...... but again if you never had this issue so do with it what you will.
ORIGINAL: xfasteddiex
helicoil in a sparkplug hole!!!! LOL
i dont think so
you better start lookin for a head or better yet a set of heads
i dont think so
it would be very wise of you to NOT try to helicoil the head ON the motor... take it off to fix it.
Advance Autoparts sells the tap and thread replacement kit.
Golfsito
10-06-2015 11:02 AM
