My stang is retarted... (problems)
Old 04-01-2008, 02:10 PM
tp65
tp65's Avatar
Default My stang is retarted... (problems)
Well i have a Auto 94 gt... 134,xxx miles or so. The problem is my car just starts slipping out of OD like crazy out of nowhere. It can happen like only twice a week. Sometimes it goes into OD and shifts into 3rd and sometimes into neutral then the third.. I dont know whats going on with that. I dont know if i need my tranny flushed or not.
Well there is one more thing. I few mins ago, before I came in my car just died when i put it in reverse.. It did it like 2 times, and then the 3rd time it didnt die...? wats up with that? I have already done all my tune up's and everything. And i checked timing and i have checked my tps.
tp65 is offline
Old 04-01-2008, 04:07 PM
tp65
tp65's Avatar
Default RE: My stang is retarted... (problems)
bmup
tp65 is offline
Old 04-01-2008, 07:21 PM
jperz89lx
jperz89lx's Avatar
yeah start by getting new fluid...how long as it been since its been changed?
jperz89lx is offline
Old 04-01-2008, 08:24 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Do the 94's have AOD or AODE??? Try running some Lucas Oil Stablizer and see if that helps any.
projectresto83 is offline
Old 04-01-2008, 08:53 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
94 has an aode...an you should start by running a koer test and scan for any tranny codes.....if none exist.. the overdrive band may be starting to fail = time for a rebuild[:@]
mjr46 is offline
Old 04-01-2008, 09:11 PM
projectresto83
M.A.D. Motorsports
Yup rebuild is in order for ya. Might as well get a stall converter, shift kit, etc. But like I said try some Lucas and see if that helps for a little while till you get the chance to rebuild it.
Old 04-01-2008, 11:39 PM
tp65
tp65's Avatar
ok thanks for the info guys. I cant remember the last time it was changed. I asked a buddy of mines with a aode he said when his car starting doing that he replaces the "MLP" rang selector.. and it stopped. Could that also be the problem?
tp65 is offline
jma2
07-10-2023 01:00 AM
Roxon68
03-17-2016 08:13 PM
sjforcup19
09-15-2015 09:58 AM
v8sn95
09-07-2015 10:17 AM
Luke9222
09-04-2015 06:46 AM
Quick Reply: My stang is retarted... (problems)
