installed clutch.Now have loud squeaking
Old 04-02-2008, 04:16 PM
86GreenMachine
86GreenMachine's Avatar
Default installed clutch.Now have loud squeaking
I just finished installing my centerforce dual friction clutch and release bearing and now i have a loud squeaking coming from the the bellhousing.Took cover offwhere the cable attaches to the clutch fork, if i put my hand on the fork the squeaking stops as well as when i put my foot on the clutch.Could i have gotten a bad release bearing.What else could i check?
86GreenMachine is offline
Old 04-02-2008, 04:52 PM
86GreenMachine
Default RE: installed clutch.Now have loud squeaking
Anyone ??????
Old 04-02-2008, 05:00 PM
brentloftis
brentloftis's Avatar
Did you grease the bearing and replace the pilot bearing as well? Can you add a small amount of tension to the cable to stop the noise? How is the drive-ability, notice anything on the test run?
brentloftis is offline
Old 04-02-2008, 05:06 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: brentloftis
On top of that and you could have gotten a defective t/o bearing. What brand did you get?
PRO50SC is offline
Old 04-02-2008, 05:09 PM
OnyxCobra
OnyxCobra's Avatar
Sounds like exactly the problem that occurs when the throwout bearing is bad.
OnyxCobra is offline
Old 04-02-2008, 05:10 PM
86GreenMachine
Yep i greased the bearing.No i didnt replace the pilot bearing.The clutch felt super lite on the test run.I had about 1-2 inchs of freeplay in the clutch pedal, untillI adjusted the firewall adjuster and lost all of my free play, and the pedal is a bit stiffer to.Ya i can put a lil tension on the cable and it stops.But the cable is already pretty tight already.
Old 04-02-2008, 05:13 PM
86GreenMachine
Its a centerforce t/o bearing.And yes thats exactlay what im thinking its a bad t/o bearing.If it is centerforce is gonna hear from me
Old 04-02-2008, 05:17 PM
brentloftis
Yeah sounds like the bearing.
I have to ask though, when stabbing thetrans did it hang by the shaft at anytime?
Old 04-02-2008, 08:11 PM
86GreenMachine
What exactly do you mean by "stabbing"
Old 04-02-2008, 09:50 PM
brentloftis
Sorry guess its not a common term, but the shaft to the flywheel. Just curious if a bent shaft could be hitting the bearing and when putting pressure on the fork if it evens out.
mtgldr
02-03-2024 09:00 PM
ak98
02-18-2023 08:36 AM
2007CalSpec
12-13-2020 11:42 AM
bjdutch2005
03-24-2017 03:38 AM
Quick Reply: installed clutch.Now have loud squeaking
