Engine Revs itself?
Old 04-02-2008, 06:01 PM
BumbleBeast
BumbleBeast's Avatar
Default Engine Revs itself?
I bought my 1995 5 speed Mustang GT, about 4 months ago.
After Driving around for a while I noticed that it starts revingitself when I'm not moving. It'll normally rev the engine from 500rpm up to 1,000rpm sometimes it'll drop a little bit more below 500 and will jump up that much higher above 1,000. It gets very annoying at long stop lights and it's wasting a load of gas.
Anyone know what might cause this to happen? Any info would be much appreciated.
BumbleBeast is offline
Old 04-02-2008, 06:37 PM
ColdCityMustang
ColdCityMustang's Avatar
Default RE: Engine Revs itself?
At firs thought I would say a throttle posistioning sensor (TPS). Lol my ford truck would do that too, its embarassing and wait untill the car next to is a cop ....thats a bad day right there
ColdCityMustang is offline
Old 04-02-2008, 06:47 PM
sultan68
sultan68's Avatar
http://www.muscularmustangs.com/iac.php
give that a whirl
theres a few things there to try to fix an idle problem
sultan68 is offline
Old 04-02-2008, 07:20 PM
94StinkinLincoln
94StinkinLincoln's Avatar
that would be a surging idle, what mods do you have?
clean the maf and iac and that will help alot.
94StinkinLincoln is offline
Old 04-02-2008, 07:24 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
run a koeo/koer test and check for codes..if none clean Iac , then maf, then look for vaccum leaks
mjr46 is offline
Old 04-02-2008, 09:19 PM
etsxp
etsxp's Avatar
mine did the same thing when it was cold, i just cleaned the maf and i was good to go
etsxp is offline
Old 04-03-2008, 11:22 AM
BumbleBeast
Wow thanks for all the info everyone. I'll try all of those and hopefully that'll fix the problems.
I dont even know all the mods my car has yet, i know the stuff i've done, but not what the past owner has done, other than an upgraded clutch (which is insanely hard to press) and a cold air intake.
edit:: Here is a photo of the car when i first got it, since then i've replaced the old foggy headlights with some new ones. and added a few other things inside.
http://photos-c.ak.facebook.com/phot...64850_3997.jpg
Old 04-03-2008, 11:28 AM
aode08
aode08's Avatar
On the 1995 , alot of times at the dealership, I have cleaned the MAF Element , Cold Air Intake Sensor on the Air inlet tube(air filter), and repalced the air filter if dirty.
Any IAC issues, it gets replaced if OEM, I have cleaned plenty, some come back, some dont, , others work by cleaning, some it helps, etc etc etc, so I just replace.
aode08 is offline
Nick Oliver
10-17-2018 04:22 AM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
rksnow1
09-14-2015 08:46 PM
TfcCDR
09-14-2015 12:08 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: Engine Revs itself?
