Spout ???
Spout ???
ON the sn-95 mustangs with the 5.0 the Spark plug output connector (SPOUT) is located on the passenger side of the engine, underneath the mass air flow meter. The wire for the SPOUT connector is threaded through the fender and dosen't have a great deal of extra wire poking through. It can sometimes be found right at the opening of the hole. The best way to find it, for the first time is to take off the intake pipe up to the throttle body and it should be much easier to find. After you have located it, it is possible to pull the wire up a little ways out of the hole so that you can reinstall the intake pipe and unhook the connector without having to take the intake pipe off. By the way when disconecting the spout connector, it is best to do it with the ignition off. The breaking of the electrical circuit generates an electrical spike in the circuit that can possibly harm the other electronics throughout the circuit.
