BRAKE ISSUE
RE: BRAKE ISSUE
Could be a few things, like adjustment, spring, or shoes. If you had them done somewhere takeit back. Also does the noise continue if you apply a a little pressure via the emergency brake?
I had a similar noise but turned out to be a lug nut in the front wheel rolling around behind the center cap.
RE: BRAKE ISSUE
i havent tried the e-brake yet but ill get back to you on that and yes i had it done at a shop. I took it back already and they looked at the drums and said they looked fine but the noise is still there.
RE: BRAKE ISSUE
The emergency brake could help pinpoint if the drums need to be turned or it all may be just a coincidence and the wheel bearing is going. Either way the shop should be or should have been able to tell the difference.
RE: BRAKE ISSUE
Apparently thedrums were turned and its a shop that deals with mustangs only but im going to go over to the shop and take the mechanic for a drive so he can hear this f'ing noise. Ill get back to ya
mungodrums
10-07-2015 04:01 AM
09-08-2015 11:50 AM
mungodrums
Suspension
09-07-2015 07:22 PM
