Trick Flow A/C Detele?
Old 04-03-2008, 08:39 PM
And then some
And then some's Avatar
Default Trick Flow A/C Detele?
A buddy of mine got the Trick flow a/c delete kit for his 89. We looked at the instruction and can't seem to make it fit the way it should. I was just wondering if anyone else has used the a/c delete bracket set up and what it takes to make it all work?
And then some is offline
Old 04-03-2008, 09:39 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Trick Flow A/C Detele?
here's the ford racing one I have.. I'd assume trick flow is similar?? that's to say it's a relocate kit to for PS??
http://i242.photobucket.com/albums/f...347pics002.jpg
http://i242.photobucket.com/albums/f...347pics001.jpg
mjr46 is offline
Old 04-03-2008, 09:53 PM
And then some
Thanks for the pics, but the one from Trick flow looks quit a bit different.The Trick Flow and the March set up look to be the same stuff, and the bracket is smaller with some spacers.
Old 04-03-2008, 09:56 PM
CantStopTheFox...
CantStopTheFox...'s Avatar
Having the PS Pump that high always looked weird to me But that motor looks AWESOME!!!! How is it running BTW?? Have you got it on the dyno/track yet??
I am thinking about doing mine because my A/C stopped working after my H/C/I........shouldn't have disconnected it [:@]
CantStopTheFox... is offline
Old 04-03-2008, 10:15 PM
mjr46
mjr46's Avatar
ORIGINAL: CantStopTheFox...
on a stand it looks high but down in the car it looks perfect...runs good..has 95 miles on it...haven't driven it much..I'm trying to locate a mysterious coolant leak...may have been the upper radiator to t-stat housing clamp..It leaked sometimes and sometimes not.......it' was either that or the t-stat housing....I don't want to have to reseal anything again so I'm hoping... I tightened the clamp and pressure tested it cold and hot with no leak down ..so we'll see
mjr46 is offline
Old 04-04-2008, 12:10 AM
jpc
jpc's Avatar
Here is a thread from awhile back, in it I posted some pics and belt size, take alook it might be some help to you ( I have the March delete kit)
https://mustangforums.com/m_1431924/tm.htm
jpc is offline
Old 04-05-2008, 01:09 AM
And then some
After several trys at it we decided it's not going to fit right. I talked him into returning itand gettingthe Ford racing unit. Thanks for the help everyone.
Old 04-05-2008, 08:11 AM
cody91mustanglx
cody91mustanglx's Avatar
return it and get the ford racing kit it is sure to fit right
cody91mustanglx is offline
vargas
06-17-2017 12:17 PM
69Volunteer
09-30-2015 10:39 AM
SteelerNation82
09-16-2015 07:11 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Gabe_mlcc
09-07-2015 11:56 PM
Quick Reply: Trick Flow A/C Detele?
