quadrant?
Old 04-03-2008, 09:01 PM
number1_kid
number1_kid's Avatar
Default quadrant?
this might sound as a stupid question
but there is so many choices for a clutch cable on summit
whats a quadrant?
number1_kid is offline
Old 04-03-2008, 09:08 PM
nitrous_bob
nitrous_bob's Avatar
Default RE: quadrant?
it's the 1/4 pie shaped piece that the cable hoos to, and rides on when you press the pedal in
the stocker is plastic self adjusting garbage...it will break and smoke your clutch
after you get the whole cable/quadrant assy. you'll only ever have to replace the cable if you break or melt it
nitrous_bob is offline
Old 04-03-2008, 09:09 PM
nitrous_bob
and by hoos...thats my new language for hooks...get w/ the program will ya ?
Old 04-03-2008, 09:23 PM
CantStopTheFox...
CantStopTheFox...'s Avatar
ORIGINAL: nitrous_bob
LOL......Just stay away from the hoosers
For the OP, check out this link....it may help you out:
http://www.musclemustangfastfords.co...ble/index.html
or this one:
http://www.maximummotorsports.com/ Click on Installation Instructions, and then Clutch Quadrant.....
BTW....the Clutch Quadrant upgrade is a MUST!!
CantStopTheFox... is offline
Old 04-03-2008, 09:33 PM
number1_kid
thanks guys
A shop will be doing the install
but here on summit there is too many choices to make for a cable
Can i get some help a bit?
Would I be good to go with this?
http://store.summitracing.com/partde...p;autoview=sku
do instructions go with this? or will the mecanic know himself just by taking it apart?
Thanks
Old 04-03-2008, 09:39 PM
CantStopTheFox...
If the mechanic does not know how to do it.....I would not be paying him for it
It is really not a hard job.......I did mine in about an hour, and I am no professional......The hardest part is getting the old one off....the new one gets on there very easy.....
I went with the UPR, with the Firewall Adjuster......Love the Quadrant and Firewall Adjuster....but the cable was VERY tight (I put my stocker back on there). Is your stock cable broke??
Old 04-03-2008, 09:57 PM
number1_kid
that part numberI gave you aint good?
My stocker was shaved and rusting so put a carquest auto parts new cable
broke in 8miles
put another one same and broke again
so......
Old 04-03-2008, 10:02 PM
number1_kid
this is what I had in mind
let me know if you think its a good set up
thanks
[align=left]
Part #
Item
Price
Qty
Line Total
Delete
[hr]
FMS-M-6397-A302 [/align]
Pressure Plate Bolts, Hex Head, Steel, Natural, Ford, 5.0L, Kit
$13.95[/align]
$13.95
FMS-M-7560-C302N [/align]
Clutch Kit, Organic, 1 1/16 in. Diameter Shaft, 10-Spline, 10.5 in. Diameter Disc, Ford, Mustang, Kit
$209.95[/align]
$209.95
RAM-BA50M [/align]
Pilot Bearing, Steel, Roller, Ford, Each
$11.99[/align]
$11.99
SUM-700100 [/align]
Clutch Cable, with Aluminum Quadrant, Adjustable, Ford/Mercury, Mustang/Capri, Kit
$68.95[/align]
$68.95
Select All
[hr]
If you have deleted any items from your cart or changed any quantities, please press the update button. [/align]
Sub Total:
$304.84[/align]
Old 04-03-2008, 10:06 PM
CantStopTheFox...
ORIGINAL: number1_kid
broke in 8miles
so......
It is not that that one is bad.......but believe it or not, the Stock cable is the best that you can get........(that is of course if it is not broken )
This is the one I went with :
http://www.uprproducts.com/shopping/shopexd.asp?id=181
It has a Firewall Adjuster.....that lets you adjust the cable tension without getting under the car.....Very NICE
But the cable was too tight.............so I reinstalled my stock cable
Old 04-04-2008, 10:33 AM
number1_kid
piece of junk Carquest autoparts cltuch cable broke again
So many damn choices for cables. But none are tested and prooven I guest
So I putting a Ford OEM Cable looks like its the only thing that works and not complicated
if it brakes again
putting clutch kit all new
Urambo Tauro
12-17-2016 03:30 PM
ccdguy
09-19-2015 05:20 PM
ponyride00
08-12-2015 01:57 PM
87FiveO
05-07-2005 03:54 PM
rockcrusher
09-27-2003 09:30 PM
Quick Reply: quadrant?
