2.73 to 4.10 speedo help
Old 04-04-2008, 11:52 AM
Dandy74
Dandy74's Avatar
Default 2.73 to 4.10 speedo help
Anyone have a p/n for a trans gear that will make the speedo close? I just want the trans to shift close to the correct rpm after the gear was changed it will go into fuel cut-off before it shifts its a 94gt 5.0 with a AODE
Thanks
Dandy74 is offline
Old 04-04-2008, 05:42 PM
nitrous_bob
nitrous_bob's Avatar
Default RE: 2.73 to 4.10 speedo help
there isn't one
your aode has a 8t drive gear which is part of the output shaft
if you use the nonford 23t driven gear (white gear) it will make it think it has 3.55's in it
the purple 21t ford gear will make it think it has 3.27's in it
other than that....no options other than a tranny teardown and replace the output shaft w/ a 6t drive gear shaft
sorry.... t5's have a circular gear clipped on the output...so it's a simple swap for the '90 and newer cars w/ 8t....the older have 7t and good to go
but for 4.10's....even on 5-speeds 7t still requires you to go 23t gear which is the wrong pitch for any ford trans...just moreso for aod cars.
nitrous_bob is offline
Old 04-04-2008, 07:17 PM
Dandy74
Dandy74's Avatar
As always thanks for the input. I really nee to get the trans to shift before fuel cutoff so i guess i will just get a tune i think thans my only other option thanks
Dandy74 is offline
mtgldr
02-03-2024 09:00 PM
junior04
09-28-2015 10:53 AM
stealth_GT
The Racers Bench
09-22-2015 02:19 PM
Urambo Tauro
09-07-2015 12:47 PM
Figure8allday
08-22-2015 11:11 AM
Quick Reply: 2.73 to 4.10 speedo help
