1988 gt wont start when it is warmed up help!
Old 04-04-2008, 11:21 PM
Stangnsnow2
Stangnsnow2's Avatar
Default 1988 gt wont start when it is warmed up help!
I have a 1988 mustang gt and i just got it a few months ago, the problem im having is that is wont start after i drive it a few miles and the car warms up. when i go to start it again the starter is having a really really hard time turning the motor over and eventually just doesnt do anything, i can roll and jump start it. it start perfectly fine when it is cold...any ideas?
Stangnsnow2 is offline
Old 04-04-2008, 11:30 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: 1988 gt wont start when it is warmed up help!
if you have a stock exhaust and don't have full length headers that wrap around the starter...first thing I'd check are all the connections and after that check for voltage drop on the wire down to the starter and if all is okay ..replace the starter...windings may have high resistance in them and as engine heats up....surrounding heat in bay is also absorbed by starter and heat soak to the starter will up the resistance factor and reistance will cause most likely the internal voltage drop in the starter= slow crank on hot start.......but make sure battery is good and passes a load test too
mjr46 is offline
Old 04-05-2008, 12:09 AM
ckyguy68
ckyguy68's Avatar
TFI MODUALE
ckyguy68 is offline
Old 04-05-2008, 12:51 AM
Boosted5.slow
Boosted5.slow's Avatar
hmm i have an 89 gt, and you know what im fighting the same problem right now. It used to just do every once in a while i would drive some where and stop and park and come back out and try to start it. i would turn the key and it would turn the motor over so slowly like had a dead battery or something but that wasnt the case. And now its been parked for like a month and the battery is fine. Ill go to start it and it will start up fine once. but if it dies cause the car is cold and hasnt been driven it will not start again. i try jumping it but it doesnt seem to help. SO if anyone knows anything let us know..
sounds like a dead battery but there is something else going on..
Boosted5.slow is offline
Old 04-05-2008, 08:15 AM
cody91mustanglx
cody91mustanglx's Avatar
IGNITION PROBLEMS
cody91mustanglx is offline
Old 04-05-2008, 09:18 AM
xfasteddiex
xfasteddiex's Avatar
if it was a chevy i would say the timing was advanced to far but im just learning the fords much more complacated than the old chevys
xfasteddiex is offline
Old 04-05-2008, 11:49 AM
my little red 90
my little red 90's Avatar
go from easiest to check to harder:
check all electrical connections in the starter curciut. clean and then re- tighten. many times the problem is a poor/faulty ground, so look there real good.
check the timing. my 90 was set at 12* and was hard to start warm on hot days. at 10* it was better. i cleaned the battery terminals and it was good. which one was it? IDK.
then tackle the starter.
my little red 90 is offline
Old 04-05-2008, 11:50 AM
Boosted5.slow
Yea sky said maybe TFI module. i looked it up and sometimes they get condenstion inside and screw everything up when they dry out i guessing thats the thing that comes off the distb...
Old 04-05-2008, 08:55 PM
getyousome111
getyousome111's Avatar
I dont know if this will help but my brothers 87 lx did the same thing come to find out that the dual oil filters were mounted to close to the coil and causing it to get way to hot and it deteriatied it and also he had a yellow top optima battery which like a deep cell battery and it wasnt charging all the way with the stock alternator.
getyousome111 is offline
zsmart
Convertible Tech
02-29-2016 08:33 AM
1TUFF302
11-05-2015 04:02 PM
StalkerGT
09-25-2015 02:41 PM
vintageaion
09-08-2015 10:45 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: 1988 gt wont start when it is warmed up help!
