302 rebuilt hi
302 rebuilt hi
hi
i have stoke 302 88' not ho engine
whit e6se head (65 cc ) / holley 4150 600 dp / Weiand Stealth \ standard aod
one of my piston was broken and i thinking to buy pistons from 69 302 engine.
now i searching a cam , so what are u recommend ?
thanks
thanks
RE: 302 rebuilt hi
you mean burned piston??? if so you'll need machine work..never seen a broke piston that didn't cause cylinder wall damage....as for cam....ditch the heads a cam will be worthless with those heads
RE: 302 rebuilt hi
also if it's non h.o it'll most likely have a flat tappet cam in it but check casting number on block to make sure cause you gotta know what it has before you can order right parts.
RE: 302 rebuilt hi
on the bloke i have large s
and s in the head
the piston broken by me outside the bloke .
the blok is in excellent condition .
i can't chaneg the head riht now . so i need to make the bast with this head
and s in the head
bradleyb
11-27-2015 07:50 PM
Matt's 95 Stang
10-05-2015 07:16 AM
