What are these holeS??????
Old 04-05-2008, 07:17 PM
jerod187
jerod187's Avatar
Default RE: What are these holeS??????
well i mighta f***** up! the 2nd plate on my waterpump 1 out of the 2 bolts that hold it in place is stripped but i still put it together because i was pissed off, i wonder if it will leak?
jerod187 is offline
Old 04-05-2008, 09:36 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
It might. Water pumps are not that expensive though. I used the copper coating stuff in the rattle can whenever I do water pumps and thermostats. I have the same extra holes and thought the same thing for a little while till I got to looking at pics of other peoples engines.
projectresto83 is offline
Old 04-05-2008, 10:44 PM
cleanfitty
cleanfitty's Avatar
ORIGINAL: mjr46
and reinstall all bolts and the ones you are missing
He's not missing them.
dime had the same issue and ended up filling them up with JB weld.
Some standard rotation 80's ford wp's had these extra bolts that go into the timing cover. The same timing cover was used over the years for both standard and reverse rotaion pumps, and these holes don't get used, but shouldn't leak.
cleanfitty is offline
Old 04-06-2008, 03:14 AM
jerod187
jerod187's Avatar
ok cool wlell im wating for the RTV to dry now but im thinking that the water pump plate might leak now with only 1 bolt holding the button? any thoughts! lol+
jerod187 is offline
Old 04-06-2008, 08:08 AM
projectresto83
M.A.D. Motorsports
Try it and see what happens. If it does, go buy a new one. If you are that worried about the leak. Go buy a new one anyway. Or try and fix what you stripped.
jwog666
12-27-2021 08:09 PM
jrrhd73must
10-02-2015 09:17 PM
shrkbate
10-02-2015 08:25 PM
fastbackford351
Convertible Tech
09-27-2015 06:51 AM
EASTIDEE123
09-15-2015 11:08 AM
Quick Reply: What are these holeS??????
