Power loss? or how its is?
Bought my 89 hatch last fall and when I get on it, It has all the ***** in the world until 3k rpm then completly falls off in power and cruises to 5.3k when i shift, It had BBK LT's, MSD cap & rotor, MSD plugs, MSD ignition coil, BBK In fender CAI modified to a in engine bay CAI for lack of a wheel well thx to the previous owner, Off road H-pipe, Dynomax Bullets, and Underdrive pullies...
I asked a few guys I work with who either know their cars or have owned fox bodies b4 and they said it was most likely a slipping clutch and i should notice a difference if i get a good one in it.
JW if you guys think this is the main problem or is that just how the engine is?
o ya, just ordered a bunch o' crap for it, O/R Xpipe is in, super 44 flows dumped, Pro 5.0 short throw (<3), BBK strut tower brace, and soon to be installed are new rear Control arms and ford racin progressive rate springs.
thx for any info u guys can give me.
RE: Power loss? or how its is?
ORIGINAL: poopaloop
not sure how much experience driving you have, but you should know if its the clutch. There is a big difference between the car still pulling, even if its slowly, compared to the rpms going up but the car does not accelerate.
haha sry guys this is my first manual car so idk what a "bad" clutch feels like yet...
Whats happening is its pulling like a raped ape from like 1k rpm to 3k rpm then it just falls way off in power and stops pulling. just slowly climbing the rpms to when i shift, like i have a 150 shot of nitrous and let off of it at 3k. like 220 hp from 1k to 3k to 50hp until 5.5k
hope that explains it better
try running a koeo/koer test before throwing parts at it and see if there are any codes/probs the ecm sees and from there try cleaning the maf if it is a 89 and up stang and check and make sure the fuel filter is not restricted/plugged up
trust me a good tune up wont do jack thats the same problem im kinda having on my car and i waisted about $200 on a major tune up to see if it will run and nothing yet im taking it to get the cat gutted out and run a code test to see what happends if not im just going to end up selling it
also ....you could try to loosen down pipes a little creating an exhaust leak and see if power comes back.. if cats are plugged it'll cause a lack of power too
mk ty for the advice, btw... i dont have cats and i added the MSD ignition stuff very recently and all new plugs, (bosch +4s), better throttle response but no power difference.
thx again
thx again
