a/c elimination
a/c elimination
Ok, i have my a/c disconnected, but i would like to take that dam compressor off the top of my engine and clean the engine bay up a bunch, plus get some weight off, but the "a/c eliminator" kits in summit from like march say they do not include a pulley, so this leads me to believe that they are just for puttoing an idler in the place of the a/c. I want to totally remove the a/c if i can. I know i just cant run a belt without it there (tried that lol) so i was wondering if someone sold a bracket like the original non a/c one to move the p/s up. I found the full kit on march's website, but 513 is a little spendy for some aluminum braketry just to make it look good. Any parts that i can use or someone who makes something would be appreciated. thanks.
RE: a/c elimination
RE: a/c elimination
ok now my question is can i just bypass my smog pump, or will the belt rub somewhere for that too? i have all the smog crap off the car, but the pump is still there. thanks
RE: a/c elimination
Smogpump you can simply get a shorter belt for. The AC one on the other hand you would need to relocate the power steering pump or get a replacement idler pulley for it. Not sure what size belt you need to do that like that though. You are going to need to readjust your idle after you take off the smog pump and AC or you are going to be idoling at like 1300 RPM
trashxtrash
09-20-2015 10:49 PM
09-17-2015 07:57 PM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
