finally picked up some heads...
RE: finally picked up some heads...
if you going cheap. just have the necessary work done heads hot tanked, magnafluxed, milled, and a calve job. with the cam swap i would get at least new springs and lifters. out of your cam choices get the trickflow
Ok so i'll get new lifters and springs. What should I look for as far as springs?
What exactly is a valve job? Does it involve getting new valves?
I got the heads for $70.
ORIGINAL: LOUDexhaust
but yeah, like everyone else is saying. take those heads and get them checked out by a reputable engine shop and get them resurfaced as well.
So let me recap:
I will resurface the bottom, valve job and new springs, lifters, magnaflux for cracks + hot tank, new headers if need be(already have some aftermarket ones).
What do I NEED to do about rockers and pushrods? I am digging into my savings to do this so I only want to replace what needs to be replaced. I also plan to do a minor port job, still reading up on it though.
ORIGINAL: Mustangkiler
Do not reuse your pushrods with an aftermarket cam, all you need is some ford racing hardened steel 6.27 pushrods thats waht i got and there only 40 bux.
http://www.compcams.com/Technical/FA...inGeometry.asp
ORIGINAL: LongrodLX
you could almost buy a nice set of used heads for what you will have into these
KingRando
10-02-2015 08:06 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
