AFR HEADS!
Old 04-10-2008, 09:18 PM
crueheadstang87
crueheadstang87's Avatar
Default AFR HEADS!
What is the difference in AFR"S emissions legal and the non emissions heads. I know that one will pass emissions test and the other wont but i want to know is how does the performance differ/ and if i use non emissions heads will i have to take off r plug up any hoses from smog system or anything like that. i dont have to pass an emissions test so i am not worried about that. i just wanna be sure to get the better of the two heads.
crueheadstang87 is offline
Old 04-10-2008, 09:25 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: AFR HEADS!
the emissions legal heads have the holes at the back of the heads for the theremactor air injection tube...if you purchase non emisssions heads there will be no plugging to do....all you'll have to do is remove tubing and plug tube that goes down to the cats/h-pipe
mjr46 is offline
Old 04-10-2008, 09:26 PM
5spd GT
5spd GT's Avatar
Mjr is correct....!
I personally preferred the "emissions legal" heads, for a slightly better resale value. I just plugged them up with a couple thermactor plugs, if someone needs them later that does have to worry about emissions.
5spd GT is offline
Old 04-10-2008, 09:47 PM
crueheadstang87
is there a differnce in power between the two heads?
Old 04-10-2008, 09:54 PM
5spd GT
5spd GT's Avatar
Nope, not as far as ports, but there are a few different combustion chamber sizes.
5spd GT is offline
Old 04-10-2008, 09:56 PM
mjr46
mjr46's Avatar
ORIGINAL: crueheadstang87
as long as the combustion chambers are the same cc no noticable difference in power..if emissions are of no concern..just but the non emissions heads
mjr46 is offline
Old 04-11-2008, 05:48 PM
LongrodLX
LongrodLX's Avatar
same power
LongrodLX is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
kevsgt
10-09-2015 10:12 PM
mustangheaven
10-07-2015 10:23 AM
Drastang
09-30-2015 03:48 AM
Quick Reply: AFR HEADS!
