need help afr heads install?
Old 04-14-2008, 12:22 AM
cheetha94607
cheetha94607's Avatar
Default RE: need help afr heads install?
so sould i enlarge the accessory brackets to fix this problem or sould i buy the plugs. also do these plugs plug these holes or just reduce the size.
cheetha94607 is offline
Old 04-14-2008, 05:43 AM
89Ford
89Ford's Avatar
they reduce the size, its probably best to use the plugs, unless you are cheap like me
89Ford is offline
Old 04-14-2008, 05:58 AM
306stang
306stang's Avatar
Don't drill a thing!
Do it right
306stang is offline
Luke9222
10-22-2015 11:55 PM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 08:51 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: need help afr heads install?
