popping noise
Old 04-12-2008, 05:15 PM
89mustangfive0
89mustangfive0's Avatar
Default popping noise
ok so i just put edelbrock heads on and now its all back together and when i drive and i punch the gas i hear a pop noise sometimes...anyone know what it could be...im thinking mabe timings off but i didnt remove the distributor so..helpp
89mustangfive0 is offline
Old 04-12-2008, 05:30 PM
floodzilla
floodzilla's Avatar
Default RE: popping noise
does it bogg down too when this happens? if so, it might have a bad valve, maybe damaged in shipping.
floodzilla is offline
Old 04-12-2008, 05:34 PM
89mustangfive0
noo it dont bog...it jus kinda makes a pop noise..like i was cruising at like 50 and i smashed it and it made a pop noise...i kinda think my msd box is no good is that possible
Old 04-12-2008, 05:35 PM
89mustangfive0
o yea and the valves were already on my car my dad put it all together ( hes a certified tech lol )
Old 04-12-2008, 05:51 PM
floodzilla
floodzilla's Avatar
oh alright, it could be the box, or your timing could be off
Old 04-12-2008, 06:18 PM
PJC Racing
PJC Racing's Avatar
Check the plugs and wires for a misfire
PJC Racing is offline
Old 04-12-2008, 07:05 PM
crvtkilla
crvtkilla's Avatar
lean backfire maybe? like he said above i would pull a plug or two to check things out.
crvtkilla is offline
Old 04-12-2008, 07:25 PM
89mustangfive0
ok good...i noticed it did it when i pulled my super chip out..so i put it back in and it stopped but i will check the plugs..if its lean how do i fix it?
Old 04-12-2008, 07:39 PM
cody91mustanglx
cody91mustanglx's Avatar
myn did the same thing, check ur plugs, i put new plugs in and it runs fine, also how hot does ur car run?
cody91mustanglx is offline
Old 04-12-2008, 07:42 PM
PJC Racing
PJC Racing's Avatar
What plugs did you use with Edelbrock heads?
Quick Reply: popping noise
