Little AC help needed
RE: Little AC help needed
I unplugged the blower and tested the voltage, it's at 11.23. I figure that's still good. But the blower still isn't coming on. What else do I check before I start buying parts? The blower doesn't look easy to replace. How can I test the switch?
ORIGINAL: PRO50SC
Ok now check for ground on the other side of the plug. If you have power and ground at the plug for the blower motor, the motor is bad.
I made a mistake and was testing the wrong plug. The blower plug is the one way up underneath the dash, up against the firewall right? When I disconnected this and tested, I'm only getting 2V. So where do I go from here?
Did your stero come install include a wiring kit or did you splice into the wires? What setting do you have the speed set to when you get 2V and is the engine running?
Low = 3.5 - 4.5
Med Low = 5.5 - 7
Med Hi = 7.5 - 10.5
High = 11 - 14
Low = 3.5 - 4.5
Med Low = 5.5 - 7
Med Hi = 7.5 - 10.5
High = 11 - 14
ORIGINAL: brentloftis
Low = 3.5 - 4.5
Med Low = 5.5 - 7
Med Hi = 7.5 - 10.5
High = 11 - 14
Low = 3.5 - 4.5
Med Low = 5.5 - 7
Med Hi = 7.5 - 10.5
High = 11 - 14
Dude! This was a bucket of good information. Thanks.
I spliced into wires for the stereo install.
The speed setting was at low. I'll test again at high and see what voltage I get.
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
