Early upshifting
Old 04-13-2008, 08:33 PM
smokey2valve
smokey2valve's Avatar
Default Early upshifting
Got my stupid 85 GT (Auto, CFI) Running again. I took it out for a drive today, and the damn thing upshifted at 2000RPM under WOT. My guess would be the kickdown is out of adjustment, right? Its the solid linkage (Not a cable) Is there a proper way to adjust this? I ended up holding the poor thing in first just to be safe. (I hear its easy to **** em up if the Kickdown is out of adjustment) Am I thinking pretty clear? Is there a proper way to adjust the damn thing?
smokey2valve is offline
Old 04-13-2008, 08:41 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Early upshifting
check to see if the bolt fell out of the kickdown rod..my 85 used to be cfi with an aod...... the proper way is to have a pressure gauge hooked into the test port and place it in gear and set rod length until pressure falls into spec......however i SET mine to feel and you can get it close enough... there should be a rod down to the tranny from the THrottle linkage that is adjustable......adjust it is small increments and test drive it until it feels right at the setting you put it at
mjr46 is offline
Old 04-13-2008, 09:01 PM
smokey2valve
Thanks MJR! Yeah, It took me two tries, but its back to where it used to be. You ever have a problem with the trans leaking right where the cooler lines are? My bolts are tight, but it leaks right from the top line where it bolts to the trans. And theres smoke comin off of my Y pipe. Other than that, the car is almost ready for everyday driving!
lincolnshibuya
12-08-2015 04:37 PM
FivePointToTheOh
10-02-2015 04:09 PM
guitarman376
09-30-2015 05:54 PM
yourmom6990
09-14-2015 10:52 PM
FivePointToTheOh
09-14-2015 03:35 PM
Quick Reply: Early upshifting
