if its a 94-95 yes 65mm would be correct. if its a prior to 94 its only a 55mm. you want your maf bigger than or equal to your tb size so if you want to increase your maf you can but if its calibrated now i dont see an issue with it. why do you feel you need a bigger one?
Well the throtle body is a 65mm the sensor is stock, I thought I would need one calibrated for 24 since mine is 19, its a 91 5.0 coupe. Thanks for all the help by the way.
