new oil pan
Old 04-15-2008, 07:07 PM
dzornes95
dzornes95's Avatar
Default new oil pan
i'm replacing my oil pan but the new one only has one drain plug...does that matter???
dzornes95 is offline
Old 04-15-2008, 07:26 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: new oil pan
if it doesn't have one at the front then you'll never be able to drain the dirty oil in there...is it the exact same one ??? but without a second drain plug
mjr46 is offline
Old 04-15-2008, 07:27 PM
dzornes95
dzornes95's Avatar
yes,it has a bigger drain plug in the back
Old 04-15-2008, 07:32 PM
mjr46
mjr46's Avatar
where did you get it??
mjr46 is offline
Old 04-15-2008, 07:36 PM
dzornes95
dzornes95's Avatar
it came with the car when i bought it, the other one was (fixed) but the back plug still leaks a bit...the guy said he bought it for the car??
Old 04-15-2008, 07:39 PM
mjr46
mjr46's Avatar
gotta wonder where it came from if it's even for a fox..I have always seen them with the two plugs not one[&:]
mjr46 is offline
Old 04-15-2008, 07:43 PM
dzornes95
dzornes95's Avatar
wow..that is wierd..yeah i always thought they had 2...that sucks,where shoul i go from here? thanks for replying
Old 04-15-2008, 07:46 PM
floodzilla
floodzilla's Avatar
id suggest trying to fix the origonal. regular part stores sell this special goo stuff that acts like a clot for drain plugs with messed up threads or leaks and seals them.
floodzilla is offline
Old 04-15-2008, 07:50 PM
dzornes95
dzornes95's Avatar
sounds like a plan
thanks flood
Old 04-15-2008, 08:06 PM
jkrum10238
jkrum10238's Avatar
j b weld works wonders
i had a HUGE crack rusty and draining oil like no other on my truck and i cleaned it up and put a nice coat of jbweld over everything and its dry as a bone
jkrum10238 is offline
Quick Reply: new oil pan
