Rebuilding a t5
Rebuilding a t5
So I'm rebuilding another t5. Anything I should replace while I'm rebuilding. I've already got my kit and a bearing retainer. Is there anything else I should get before I do my rebuild???
RE: Rebuilding a t5
depends on why your rebuilding it...if it grinded between shifts you should inspect for damaged/mushroomed teeth cause then you'll need gear/syncro hub if any show such problems
