re:how to check compressioon on a 5.0
RE: re:how to check compressioon on a 5.0
This article will tell you how to set it up on TDC
https://mustangforums.com/m_3264510/tm.htm
Compliments of AdderMK2
hey guys i friend off mine told me to move the distributor around and crack it so i did and the car started right up,but i try to rev it and it takes a couple off seconds to the gas to go up and a hear like a explosion whats that mean if you can help me out
heybig bi friend off mine told me to move the distributor around and crank it so i did and the car started right up,but i try to rev it and it takes a couple off seconds to the gas to go up and a hear like a explosion whats that mean if you can help me out
as long as it is running you need to do the timing first...warm it up , remove the SPOUT connector and then set it. if you do dnot remove the SPOUT b4 changing it, it won't take right.
sears has digital multi-meters on sale right now for $12.50
get one
do the timing and go from there.
get one
