interesting idle ?
Old 04-18-2008, 12:32 AM
poopaloop
poopaloop's Avatar
Default interesting idle ?
for a few weeks now everytime i start my car it will start fine, idle at 1200ish for a few seconds drop to 900rpm idle for a minute or two then start going from 1500rpm to 500rpm just lopeing like it has a MASSIVE cam in it then after about 3-5 minutes of that it idles at 900-1000rpm like normal.
what is causin this? i cleaned th IAC and Throttle body but nothing happened. any ideas?
mods are...
89 gt, bbk CAI, UD pullies, bbk LTs and o/r x pipe, flows dumped, brand new msd cap, rotor, wires, coil (was doing it b4 ignition was installed), bosch +4 platinum plugs.
poopaloop is offline
Old 04-18-2008, 06:03 AM
poopaloop
poopaloop's Avatar
Default RE: interesting idle ?
bump.
Old 04-18-2008, 10:35 AM
tmuti13
tmuti13's Avatar
Check your vaccum lines
tmuti13 is offline
Old 04-18-2008, 01:54 PM
cdougherty
cdougherty's Avatar
My first time offering advice... but I had the same problem and it's very likely your Idle Air Control valve. It happened to me and I replaced it and it all worked fine. I would definitely shop the IAC around though. I bought mine at a dealer and it was waaay too much $$. Check Mustangs Unlimited or the like... I think I saw it for around $75. Also, make sure you get the little gasket for it. Check my similar post on the topic.
cdougherty is offline
Old 04-18-2008, 02:33 PM
jtmustang
jtmustang's Avatar
iac valve take it off and clean it off and/or vacumn lines off or broken somewhere
jtmustang is offline
Old 04-18-2008, 07:00 PM
poopaloop
poopaloop's Avatar
mk ty guys
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
mdg
10-01-2015 07:04 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: interesting idle ?
