Mass air question
Old 04-18-2008, 01:07 AM
RanDJ8487
RanDJ8487's Avatar
Default Mass air question
Okay upgrading my car to 24# injectors so I have to get a new mass air. I know stock is 70mm and the car currently has a 75mm, how big can you go like what would be a max or min or whatever.... thanks for your help n please dont hurt me for now knowing I just saw an 80 mm for cheap
RanDJ8487 is offline
Old 04-18-2008, 01:54 PM
dudeboy
dudeboy's Avatar
Default RE: Mass air question
IF the 80mm unit is properly calibrated for your 24's AND your ecu, then it will work well for you.
dudeboy is offline
Old 04-18-2008, 06:08 PM
RanDJ8487
RanDJ8487's Avatar
http://cgi.ebay.com/ebaymotors/80mm-...spagenameZWDVW
well im looking at that item there. Should it work?
Old 04-18-2008, 07:31 PM
silver91gt
silver91gt's Avatar
that will only work with cobras
silver91gt is offline
Old 04-18-2008, 07:34 PM
my little red 90
my little red 90's Avatar
i'd get a C&L that was calibrated for your 24# injectors and was a fit for your ecu. junk here will plague you forever! some MAF's can be recalibrated for differens injectors. i think pro-m is one of them. call and ask. it would be cheaper.
my little red 90 is offline
Old 04-18-2008, 10:57 PM
RanDJ8487
RanDJ8487's Avatar
You're right, it can be recalibrated. In case anyone else has this problem and searches this thread, the link to send in your meter is
http://www.promracing.com/recalibrations.htm
they also calibrate the stock ones
Old 04-19-2008, 02:19 AM
dudeboy
dudeboy's Avatar
ORIGINAL: RanDJ8487
When you see this...
80mm MAF 87/04 Mass Air Meter Sensor Mustang Cobra 5.0
a red flag should go up...
1987 and 2004 MAF meters are not interchangeable.
1987???
Generally speaking ebay is a crappy place to buy a MAF meter, unless you know EXACTLY what to look for... by Ford part number.
You are looking for an aftermarket MAF meter, not a stock Ford unit.
There aren't any Ford meters that will work with the 24's...
Look into...
Abaco (may not be on the market yet)
ProM
PMAS
C&L
All of these meters can be 'recalibrated' if you decide to change the injector size later. The cost will vary for this though, as each company 'calibrates' differently.
jason
dudeboy is offline
Old 04-19-2008, 06:59 AM
Joel5.0
Joel5.0's Avatar
ORIGINAL: RanDJ8487
Nope...... like Jason said, no OEM MAF units were "calibrated" to a specific injector size.
Joel5.0 is offline
Old 04-19-2008, 09:23 AM
white93pony
white93pony's Avatar
im gonna argue this. i bought a set of 24 and a mass air off a 93 cobra and put them on my 89 and they worked perfectly. had no problem with it at all. fyi it diddent have a chip either so....
white93pony is offline
Old 04-19-2008, 02:01 PM
dudeboy
dudeboy's Avatar
ORIGINAL: white93pony
Are you running an A9*?
What sensor is on the MAF housing?
Verify the Housing diameter?
Assuming you have the parts you claim to have,
You may not know it, but you DOhave problems...
Get a wideband O2 sensor on the car, and see what the AFR is...
dudeboy is offline
Quick Reply: Mass air question
