Porblem Installing Short-Throw
ELEKTRO-FIDE Moderator
Location: In Geo-synchronous orbit over redass' bathroom,
RE: Porblem Installing Short-Throw
ORIGINAL: TRexGAWD
We've already told you. Either take off the center console(which you probably can't because the screw heads are stripped) or use a ratchet wrench. There's really no other way to do it unless you feel like breaking it or putting holes in the console.
the problem is that fact that even with a ratchet wont the console keep the bolt from coming out cuz the bolt is too
long?
my suggestion, when you put it back in, leave those 2 out, i can get the lower boot bracket in over the shifter with a little finesse, and then get the 2 back ones in, keeps it in place, and no removal of the console
you cant get a wrench in there?
i can get the wrench in there, but it seems to me that the bolt will make contact
with the console BEFORE the bolt is all the way out
those 2 console screws (4 if u count the ones hiding behind the glove) are a pain. you just gotta get the right size screwdriver so you dont strip them and turn them like you mean it. i took a dash out of a junkyard car that those were the HARDEST screws to get out. prolly experience the most body flex there i guess
and you should try to remove the console and do it right the first time
i did not read all these... but so far it is not accurate at all
that inner rubber boot is nothing more than a dust shield to keep debris out of the car and possibly a 1/2 decibal of road noise. i have replaced about 10 shifters, my cars, buddies cars etc.
i have NEVER taken out the console for it EVER
you just need a short wrench to get those 2, 8mm if i remember ?? or 10 at the biggest.
if you use a short wrench , all you get is about 1/4 turn, but they are short bolts. i never put them back in.....just the 2 easy ones.
I put a triax in my 87 gt last month. I can feel your pain. It took prob. 2 hrs and half of that was due to these two bolts.
I had to pick up an open end offset wrench and then could only get 1/4 turns. Harder yet is getting them back in once the new shifter is in place it sits a little higher giving you even less clearance to get the bolts back in. but I got them in and out without removing the councel. Good Luck!
Trim the outlined area of the console. That's what I did. It will help axcess the bolts
[IMG]local://upfiles/29779/C2681DE43A334F1995DB35DE91221D30.jpg[/IMG]
ORIGINAL: simpsonfan13
dang whats with the attitude?
long?
ORIGINAL: TRexGAWD
long?
